gears? stall? or both
Old Sep 25, 2008 | 08:50 PM
1badasZ's Avatar
hey all decided to pull my car out of the bushes n start messin with it again and got it where i can finally drive it n was wandering something. i have a bad lugging problem in overdrive where the car seems to barely make power. up around 2500 n up it runs smooth n pulls pretty decent. so i was wandering if its more of a tuning issue or if i need lower gears or a bigger stall for my cam n head combo. i have the comp extreme 230/236, vigilante 2800, and 3.42 gears. thanks in advance for any info
Old Sep 25, 2008 | 09:44 PM
87bandit's Avatar
does the car "chug" are 45-50mph? if so that's the convertor locking up too early/late I forget, it's a tuning issue though if that's the case
Old Sep 25, 2008 | 09:49 PM
6SpdLT1Z's Avatar
3.73/3200rpm and let 'er eat.
Old Sep 26, 2008 | 12:10 PM
87bandit's Avatar
3200-3400 stall and 3.73s
Old Sep 26, 2008 | 02:27 PM
LSWHO's Avatar
My car does the same thing. After a couple seconds of chugging it unlocks the converter and I start to slow down, so in turn I have to give it more gas.
I haven't figured out the exact cause yet.
OP: If this is what it's doing to you then a stall and gears won't help.
I have a built tranny/3200 stall and 3.42s and my motor is STOCK and it does this. It's a TC lockup problem.
Old Sep 26, 2008 | 05:20 PM
chevy94c's Avatar
3600 & 3.73
Darth_tsunami
V6 Tech
Sep 18, 2015 01:57 AM
thenewkid
Apr 12, 2015 07:42 PM
Magenta_Hearts
Mar 30, 2015 09:42 PM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
