stumble miss: opti contaminated with KN oil?
Old Jul 15, 2008 | 10:49 PM
tlillard23's Avatar
I pulled apart my opti and noticed orange/red contaminates. I just thought it was residue from the radiator/thermostat replace. My buddy noticed the same thing on his opti. He figured out that it was K&N air filter oil. What is the chance that this is the reason all these opti's are crapping out and poor running cars? A thin film could screw with the sensor.
I was wondering if just squirting some MAF cleaner or electrical contact cleaner down the opti vacuum tube if this would help in some cases? get a glob-o-oil on the filter, or oil it too much.....
Todd
Old Jul 15, 2008 | 11:19 PM
kyle88transam's Avatar
Not to come across as a jerk, but how would you get K&N oil on the opti?
Old Jul 16, 2008 | 12:56 AM
Dave1980's Avatar
I think he is talking about if the vented tube would suck up K&N oil.(assuming that the air filter was over oiled) I am not really sure if it could, but I have heard a lot of bad things about over oiling your K&N filter.
It can coat MAF sensor elements for sure.
Old Jul 16, 2008 | 02:11 AM
tlillard23's Avatar
I like to get my opti all wet and lubed up... oh wait, that's for a different forum.
yes, from the vent on the opti. I am not a rocket scientist, but... It would seem that small amounts of outgassing materials could affect the optics. especially in a relatively high vacuum. what kind of optical sensor is this anyhow?
Old Jul 16, 2008 | 07:10 AM
mzgp5x's Avatar
Opti vent tube (suction side) stuck in ATI D1 intake. KN filter oil found inside opti internals, and, most inside the opti sensor compartment. I just cleaned it, and, will probably re-assemble and try it. What the hell. I think it will work. I will have to re-design the suction line fitting so this will not happen again. Altered (riveted) the rotor and... rotor living a long life with lots of MSD power throwen thru it. B. Hi Till.
Old Jul 16, 2008 | 09:00 AM
Ok, sorry. I'm not real familiar with the vented optispark design.
HectorM52
Jul 30, 2017 11:46 AM
95z_28_camaro_4_Ivan
May 8, 2015 09:56 AM
MattFick
Feb 15, 2015 10:16 PM
Dave19yz28
Jan 26, 2003 01:45 PM
MikeLS
Nov 21, 2001 06:40 PM
