I think my engine is stuck and wont turn
I tried turning on the car after 2 weeks of it being parked. And it turned on for like 2 secs and turned off
When I tried turning it back on there is a super LOUD noise like if the engine is stuck.. I think its not turning.
I think the starter is trying to turn the engine but it wont so it makes that llllllloud noise..
But im not sure any one think it might be something else?
Its been raining a lot down here and thats why I didnt move the car. I checked the oil and it seems fine.
Thanks in Advance
Thanks in Advance
is it a loud almost a screech kinda noise? that goes away soon as you let off of the key?
if so either the armnature isnt engauging all the way and the starter teeth are not lining upp 100% on flywheel and not locking in, or starter teeth are messed up, or a spot or spots on your flywheel have damaged teeth.
pull the starter and see what the teth on it look like. go from there.
if itr was hydrolocked it wouldnt make any noise as nothing would be moving. i seriously dought that is the problen so dont waste your time pulling plugs right now.
Thanks in Advance
Thanks in Advance
it would take alot less time to try to turn it over manually then to pull the starter... i would turn it manually first just to eliminate the suspicion of a locked up motor and then go to the starter... jmho
