I think my engine is stuck and wont turn
Old Jul 10, 2008 | 10:55 AM
Projectcam94's Avatar
Angry I think my engine is stuck and wont turn
I tried turning on the car after 2 weeks of it being parked. And it turned on for like 2 secs and turned off
When I tried turning it back on there is a super LOUD noise like if the engine is stuck.. I think its not turning.
I think the starter is trying to turn the engine but it wont so it makes that llllllloud noise..
But im not sure any one think it might be something else?
Its been raining a lot down here and thats why I didnt move the car. I checked the oil and it seems fine.
Thanks in Advance
Old Jul 10, 2008 | 12:10 PM
CGrant's Avatar
if its a kinda ticking noise your battery might be dead?
i know my car is a garage queen and if it sits for a couple of weeks the battery drains.
Old Jul 10, 2008 | 12:23 PM
Nop im 100% sure its not the battery.. I know what ticking noise your talking about.. This noise that it makes is super loud..
Thanks for responding though
Old Jul 10, 2008 | 12:32 PM
Stl94LT1's Avatar
It could be hydro locked. Start pulling the plugs and see what you find.
Old Jul 10, 2008 | 12:47 PM
Ill start removing them right now.. Can it get hydro locked just from sitting? I used it fine the last time it turned on and it wasn't raining.
Old Jul 10, 2008 | 12:49 PM
Stl94LT1's Avatar
No, hydro locked from fuel.
Old Jul 10, 2008 | 01:53 PM
cnorton's Avatar
Or from coolant through a leaky head gasket.
Old Jul 10, 2008 | 07:02 PM
bowtiedad_z28's Avatar
Sounds like the starter is bad. Mine did the same thing. I know exactly what loud noise you are talking about.
Old Jul 10, 2008 | 09:38 PM
LOW-LIFE's Avatar
is it a loud almost a screech kinda noise? that goes away soon as you let off of the key?
if so either the armnature isnt engauging all the way and the starter teeth are not lining upp 100% on flywheel and not locking in, or starter teeth are messed up, or a spot or spots on your flywheel have damaged teeth.
pull the starter and see what the teth on it look like. go from there.
if itr was hydrolocked it wouldnt make any noise as nothing would be moving. i seriously dought that is the problen so dont waste your time pulling plugs right now.
Old Jul 10, 2008 | 09:39 PM
LOW-LIFE's Avatar
oh yea where in south texas are you? if your somewhat close i will look at it for you if you like.
Old Jul 10, 2008 | 10:15 PM
SS RRR's Avatar
Thanks in Advance
Have you tried turning the engine over by hand? If not, put the car on jackstands, put it in neutral, use a long breaker bar or socket wrench w/ a 5/8" socket and extension and rotate clockwise.
Old Jul 11, 2008 | 07:39 AM
Pontiac_97's Avatar
put in a different battery. the car will make very wierd noise with a dead battery
Old Jul 11, 2008 | 07:54 AM
4THGEN Z's Avatar
I had this scenario and it was the starter....the case was cracked in half but in my case, it still started the car.
Old Jul 11, 2008 | 09:16 AM
It does go away as soon as i let off of the key. I was thinking of starting with taking off the starter and taking a look at it... If that's ok i am going to try and turn over the engine manually. Then if that doesn't move. ill take off the spark plugs..
Old Jul 11, 2008 | 10:20 AM
ZL1modified's Avatar
it would take alot less time to try to turn it over manually then to pull the starter... i would turn it manually first just to eliminate the suspicion of a locked up motor and then go to the starter... jmho
