intake plenum / fuel rail removal
Old Jun 30, 2008 | 01:54 PM
Jeremy1's Avatar
Question intake plenum / fuel rail removal
I am attempting to remove the air intake plenum (to gain access to the valve cover). I've disconnected the intake, TB hoses, vaccuum hose, throttle cable assembly, assorted electrical connectors, the fuel injector electrical connectors, the EGR flex pipe, and pulled 8 bolts from the plenum. The entire thing is loose (I can rotate it side to side), but it wont lift out. Does the rectangular plate that the fuel pressure regulator is attached to/part of need to come out (i think this is the fuel rail?)? Is there something else I am missing? Do the injectors need to come out?
Old Jul 2, 2008 | 10:02 AM
marosteve's Avatar
if i remember correctly, yes injectors do need to come out.. also did you get the 2 bolts that Gm conveniently put in the very back of the intake?
HectorM52
Jul 30, 2017 11:46 AM
LT14LIFE
Feb 9, 2015 09:35 PM
rcajun86
Jan 30, 2015 01:56 PM
birdblack
Dec 30, 2014 06:59 PM
Jul 4, 2005 05:00 PM
