Coolant leaking from behind motor...
Old Jun 26, 2008 | 05:21 PM
Myxtreme1's Avatar
Sorry, this is for a 1994 Sunbird. This is one of the best sources for info so I came here. For some reason this thing is leaking coolant between the firewall and motor. Anyone know where I can find out what is back there that has to do with the cooling system? Maybe it's the heater core, I don't know. Thanks!
Old Jun 26, 2008 | 10:53 PM
smithtim's Avatar
unfortunatley I don't the specifics of the car you're talking about; however, I can say when t comes to leaking collant don't take chances....... maybee a good idea is to really clean everything up real good I mean real good then drive the car a little ( pull the spark plugs and check inside first just to be safe)... after driving the car a little with everything cleaned up you should be able to locate your source of leakeage
How much is it leaking, is it just running a little low or is it empty???
best of luck for an easy fix
Old Jun 26, 2008 | 11:55 PM
Angelis83LT's Avatar
I do not know alot about that car either, but front wheel or rear wheel drive?
If it is front wheel, then it could very well be a heater core hose leaking, I do not recall any issues with heads or intakes. But it really should not be hard to trace. just follow the water trail.
Old Jun 27, 2008 | 04:17 PM
Myxtreme1's Avatar
FWD 3.1 V6. The fwd's make it hard to see things under the mood. I am leaning toward heater core.
blac94Z
Feb 15, 2021 09:43 PM
kallcium
V6 Tech
Oct 7, 2015 03:39 PM
Blood type Z28
Apr 8, 2015 11:34 PM
94Z28LS1toLT1
Jan 15, 2015 07:18 PM
dansam
Jul 20, 2002 01:10 PM
