cheap horsepower
Old May 23, 2008 | 07:40 AM
camarodude101's Avatar
cheap horsepower
is there any mods that can be done at home for free that i can do to my 94 V6 5-speed camaro to get more power?
Old Jun 5, 2008 | 12:11 PM
redneckgames's Avatar
I wish. Nothing is ever free
Old Jun 5, 2008 | 05:54 PM
95camaroinok's Avatar
not sure how much power it would be worth, but you could remove some of the baffles in your air filter box or take the intake tube off the air box and remove the box. Then find one of the cone style filters that has one open end and one closed, that is roughly the same diameter as the inside of the intake tube. You can put two radiator hose clamps together to make a cheap, efficient clamp for it. Not exactly free, but a lot cheaper than buyin a kit. The people that I got my 95 from had removed the air box and just threw a filter "over" the end of the intake tube..... So I just found a filter that would fit it tight and its worked great since. There is one more cheap/free one that involves your catalytic converter, but I wont go into detail there. If you want to try out the filter idea, I have the part number for the filter wrote down in my car somewhere.
Old Jun 7, 2008 | 07:21 AM
CmdrViper's Avatar
filter...
i was about to go get k&n today to replace bs fram... if you can get that part number to just hang it out...
Old Jun 9, 2008 | 02:02 PM
94-TAGT's Avatar
http://www.funkz.net/firebird/firebirdmod22.htm TB bypass at the bottom.. good for 1 imaginary horsepower.
Old Jun 9, 2008 | 06:08 PM
ImportKILLER's Avatar
You have to pay to play.
Old Jun 10, 2008 | 02:52 AM
I'll go dig in my papers for the car later today and post the filter part number. I used an STP. Should be the same number for most others, excluding k&n.
Old Jun 26, 2008 | 03:04 PM
slomarao's Avatar
many lt1 guys made their own CAI. Get a good filter some pvc piping and fab it up. Lots cheaper than buying one from k&n or moroso.
Next i would buy a muffler from summit. Get a dyno max or hooker aerochamber. They would drastically improve airflow in and out of the engine. Both should be under 150 together. Not free but cheaper than many other options.
Formula Steve
Sep 19, 2023 08:31 AM
jackpawt883
Aug 26, 2015 11:22 AM
Aug 24, 2015 06:41 AM
Slayer
Aug 17, 2015 03:55 PM
karpetcm
Aug 14, 2015 03:02 PM
