starting problems anyone i mean anyone
Old May 11, 2008 | 05:57 PM
camaroLevi's Avatar
Smile starting problems anyone i mean anyone
has anyone , any year camaro had a starting problem at all , and if so what was the answer , and what lead to the diagnosis that it was the significant problem please help , any input helps a helpless 23yr old , by the way my birthday is memorial day the 26th of may (serious)
Old May 11, 2008 | 06:03 PM
mdacton's Avatar
What is it doing?
what have you checked? will it turn over
check the batt?
Try tapping on the starter?
Old May 12, 2008 | 02:30 PM
camaroLevi's Avatar
everything but tap on the starter . it turns over so woudlnt it not be the starter??? where is the starter located on my car , do u possibly know??
Old May 20, 2008 | 07:53 AM
2000GTP's Avatar
Is the car cranking over normally, or is it cranking very slowly? It may not be a starting/charging system issue, it could also be ignition or fuel related.
Old May 20, 2008 | 06:52 PM
camaroLevi's Avatar
it acctually cranks over normally until like 10 mins of doing then the battery starts to weakin as the starts get more and more slugish , until i just hear the starter solenoids snapping then i go to pep boys and recharge my batter for free....i jus got my stimulus check so im hoping to find a real REAL real good mechanic/technician that can figure out this starting problem, and i still have that p1518 diag. code>>?
Old May 20, 2008 | 08:06 PM
mdacton's Avatar
no starts are pretty basic....
you need....
fire
compression
correct timing
fuel
air
firgure out whats missing then check that system....
Old May 21, 2008 | 10:17 AM
2000GTP's Avatar
Ten minutes is very excessive. That will easily run your battery down and can very well damage your starter. I'm guessing the problem lies elsewhere. As suggested about, those basic priniciples are what makes the car run.
Old Jun 4, 2008 | 07:33 AM
Jeremy1's Avatar
i had a problem once where the car would not start after a heavy rain if it had been been sitting. Turned out to be the coolent temp sensor (right behind the thermostat on the 3.4l). It is supposed to send a signal to the computer to run rich when it is cold or damp outside. $12 from Autozone and easy replacement.
Alex Barnes
Jan 24, 2015 10:21 PM
Oncomingstorm22
Jan 22, 2015 07:15 PM
HCz28
Jan 11, 2015 11:21 AM
97z28k&N
Jan 9, 2015 04:58 AM
97SSdude
Dec 31, 2014 07:43 PM
