5/16" Head ARP bolts (12pt or 6pt)
Old Feb 2, 2008 | 05:58 PM
ssbowtie1's Avatar
I see alot of people recommending the 12pt heads. I noticed they also sell a 6 point head (http://www.jegs.com/webapp/wcs/store...0002_133874_-1)
Won't the 6 point be alot easier to install since you can just use the open end of a 5/16 wrench? Why do people recommend the 12 point head over the 6 point?
Old Feb 2, 2008 | 06:41 PM
joeSS97's Avatar
Its easier to fit a socket on,and a wrench wont slip off it.
Old Feb 3, 2008 | 07:18 AM
jpack24's Avatar
I run the 6 point without any issues, but they are studs.
Old Feb 3, 2008 | 07:58 AM
rskrause's Avatar
Moderator
Most people use a torque wrench/socket to install head bolts, not an open end wrench The only reason I see to go for the more costly twelve pont is that if the bolt heads are very close to the springs, it is easier to get a socket on them. Ususally this is not a problem with a typical LT1.
Rich
Old Feb 3, 2008 | 10:19 AM
BTC's Avatar
BTC
From: Lansing, MI via Bowling Green, KY: Dalton, GA: Nashville, TN & Atlanta, GA
I believe he's referring to the ARP header bolts.
Old Feb 3, 2008 | 10:26 AM
BTC's Avatar
BTC
If you're working in a tight area, you wont need as much room to rotate the wrench to get a grip on a 12 point head.
Old Feb 3, 2008 | 10:37 AM
ssbowtie1's Avatar
Rich
I found some Breslin bolts online so I'm going to try and order those. If I don't get them I'll just go with some 12 point ARP's. Thanks guys.
Old Feb 3, 2008 | 10:45 AM
rskrause's Avatar
Moderator
Oops, sorry. Well, I torque those anyway
Rich
Old Feb 3, 2008 | 11:00 AM
96capricemgr's Avatar
Don't bother with the stupid locking gimicks. Only reason header bolts "loosen" is the gasket compresses and causes them to lose torque. Retighten them frequently for the first week or two is all you need to do.
Old Feb 3, 2008 | 11:05 AM
jpack24's Avatar
Part of this is true. What people forget to do when installing headers, they don't chase the threads. All that rust from the old bolts stay in there. So, when you think you got them tight, they really are not. I use studs and the threads were chased. I have never had to retighten my headers.
Old Feb 3, 2008 | 11:46 AM
rskrause's Avatar
Moderator
Use "Never Seize" or the equivalent whenever you install headers.
Rich
BTC's Avatar
BTC
If you search EBay, you can find a vendor with some stainless Breslins. The company is Boese Engineering, or something like that.
Old Feb 3, 2008 | 12:45 PM
It also depends on the gasket used, something like the Earl's Pressure master does not need retorquing but a cheapy paper one likely will.
maybe2fast
Mar 16, 2015 09:45 AM
blac94Z
Jan 22, 2015 11:19 PM
Catmaigne
Dec 25, 2014 12:16 PM
thenewkid
Nov 27, 2014 09:41 AM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
