Which one works?
Which one works?
I just simply want the one that works while saving as much money as possible. If the MBA one works sufficently I'll get that one, but I need you guys real experience and opinon. Thanks!
http://www.thunderracing.com/catalog...vid=4&pcid=219
OR
http://www.thunderracing.com/catalog...vid=4&pcid=191
Thanks guys
OR
Thanks guys
well I dont recommend this, but I found an old shampoo bottle that fit the hole really tight and just cut it off and tightened it down in there. im sure this is probably not a smart idea but it works fine.
I know you guys are trying to help and thanks but I don't want all the homemade methods, I just want ppl. who has bought or saw one of these and tell me if the plug works or does it slide out all the time even though it has a clamp on it. Gravity will be pulling against it not to mention the vibrations of the motor and I don't want to be going down the rd. and hear a clang where it's fell out.
Your better bet is to buy a 1LE intake elbow. Most stock elbows suffer from damage on the lower portion that seals to the TB.
You can find cheaper sources for the 1LE. GM wholesale price is $53.04. Thunder is selling them for more than GM list price.
alright, that's what i needed to know shoebox, it's worth the extra 50 as I suspected.
well I called yesterday and wholesale price here is 140 something 200 retail b/c they have discontinued them they said....now i tried scoggin & dickies it won't even pull up w/part number
where else could I get one besides Thunder at wholesale?
Did you try the source listed on Shoebox's "where to buy parts" page?
http://shbox.com/1/4th_gen_tech2.html#Dal_and_Jason
no man this internet at work will only let me get on certain pages and that's not one of them but I did try! I'll have to do it at home, but it's much better when you can do all this at work.
if you guys could shoot me his number i'll just call him!!!
Just say'n, if there is nothing wrong with your stocker, then why bother to spend money on a replacement. And...since you don't mention that your stocker is broken----"if it isn't broke" JMHO
As for my .02 I had the plug and never had any problems with it "falling out" when I put it in it was a little taller and stuck out into the air intake path so I had to grind it down to make it smooth with the natural path inside the elbow. Maybe they have fixed it. I recommend using a vortech or trick flow elbow myself they look nice, are smooth inside and cost about the same.
Here's the vortech.. http://store.summitracing.com/egnsea...alse&N=700+115
And the trick flow.. http://store.summitracing.com/egnsea...DS=1&N=700+115
[QUOTE=hosspwr94;5151387]I don't think it a matter of being broke or not he's wanting to take out the crappy long piece that hangs down and put in a performance piece! besides who cares its his car and his money just help the guy out!!
THANK YOU SIR!!!
Does anyone have Jason's number handy so I can call him? ALSO (Shoebox) what's the part # you have...maybe I have the wrong one. I'm just wanting to reduce turb. and get rid of the donky piece! Sorry if I failed to say that in the post i just figured it was implied
THANK YOU SIR!!!
Does anyone have Jason's number handy so I can call him? ALSO (Shoebox) what's the part # you have...maybe I have the wrong one. I'm just wanting to reduce turb. and get rid of the donky piece! Sorry if I failed to say that in the post i just figured it was implied[/QUOTE]
Sam taylor buick...jason Crommer... 1-877-726-8295
I keep his number in my cell!
