Deleting the air pump system
Ok, so ive had a ses light on since i got the car, the code is "secondary air injection system malfunction"
if i just take it all out is that going to cause any problems?
since its already throwing the code what more damage could it do?
I plan on getting it tuned out in the future but i would like to get rid of it to clean up the engine compartment a little.
i know that, im asking if my computer, completely stock is throwing a code for air, if i take it all off and leave the computer stock, is it going to throw more codes, that could possibly affect driveablity
Your PCM is throwing a code because there is a fault with the AIR system. You can either repair it and get rid of the code that way, or remove the AIR system altogether along with having the AIR specific codes removed from the PCM via tuning. If you go that route, it will not affect the driveability of the car. The AIR system is in place to reduce startup emissions.
the entire air system is pointless to me.
Heats the cats up faster.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
