Deleting the air pump system
Old Jan 30, 2008 | 10:47 AM
96supersport's Avatar
Ok, so ive had a ses light on since i got the car, the code is "secondary air injection system malfunction"
if i just take it all out is that going to cause any problems?
since its already throwing the code what more damage could it do?
I plan on getting it tuned out in the future but i would like to get rid of it to clean up the engine compartment a little.
Old Jan 30, 2008 | 10:53 AM
white97T/A's Avatar
If you take it out you will have to get the code deleted from the PCM so that the SES light wont stay on. Also you will have to plug the holes in you're headers and one in the intake tube.
Old Jan 30, 2008 | 11:00 AM
yea i know ill have to plug off all the wholes, but i already have a code, if i pull it all out is it going to throw more codes to just stay the same?
Old Jan 30, 2008 | 11:02 AM
2000GTP's Avatar
If you have the PCM tuned, it won't matter if the whole system is removed, you will not get any more AIR related codes.
Old Jan 30, 2008 | 11:05 AM
i know that, im asking if my computer, completely stock is throwing a code for air, if i take it all off and leave the computer stock, is it going to throw more codes, that could possibly affect driveablity
Old Jan 30, 2008 | 11:16 AM
2000GTP's Avatar
Your PCM is throwing a code because there is a fault with the AIR system. You can either repair it and get rid of the code that way, or remove the AIR system altogether along with having the AIR specific codes removed from the PCM via tuning. If you go that route, it will not affect the driveability of the car. The AIR system is in place to reduce startup emissions.
Old Jan 30, 2008 | 11:22 AM
ok so if i delete it nothings going to change since i already have the code?
then ill get my ecm tuned when i have the cash
Old Jan 30, 2008 | 12:35 PM
ss.slp.ls1's Avatar
Sorry that this is not my thread, and this may be a dumb question, but if you delete the system, are you guaranteed to fail CA emissions?
Old Jan 30, 2008 | 12:52 PM
i think so, but here in florida we dont have emissions at all.
Old Jan 30, 2008 | 01:02 PM
slomarao's Avatar
cali has strick visual inspections, espescially for a f body.
Old Jan 31, 2008 | 02:52 AM
rbaksi's Avatar
Sorry for the dumb question, but what exactly does the air pump do (besides the stupid "pump air" answer) ?
Old Jan 31, 2008 | 07:21 AM
2000GTP's Avatar
When you first start your car, it is running rich. The air pump basically injects air into the exhaust manifolds in order to reduce the emissions upon startup.
Old Jan 31, 2008 | 10:44 AM
i think the air pump is just a way of tricking the system. if its putting out X number of fumes, then you add air to it, its still producing the same amount its just deluted by air.
the entire air system is pointless to me.
Old Jan 31, 2008 | 10:45 AM
Depends which code you have now. In the OBD-II cars, there are two different codes, P0410 for lack of air flow to either bank of the engine (detected by O2 sensors, when the pump is cycled as part of the diagnostic), and P0412 for a fault in the electrical supply to the AIR pump (often a blown fuse). Removing the system completely will guarantee you have both codes, not just one. Will not affect driveability. But it will prevent you from seeing the SES light come on when you do have a code of some sort that will affect driveability.
Heats the cats up faster.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
HectorM52
Jul 30, 2017 11:46 AM
cmdeshon
Dec 27, 2014 10:06 AM
CamaroZBoy
Aug 16, 2002 10:03 PM
