need help tonight
need help tonight
doing injectors and i bought 95 lt1 injectors 24lbs ( i will tune) and my stock injectors are 1/8 inch bigger will that be a problem?? i have it all taken apart right now and it has to be done by morning so can anyone help me??
Bigger as in longer or in the diameter where the seal grove is? My accell injectors were slightly shorter and had no problem, just cycle the key a few times and check for leaks before staring if they are shorter.
