355 with heads and intake.... which cam?
Old Jan 19, 2008 | 11:42 PM
johnnyb's Avatar
Im building a 355 with just about every possible bolt-on, along with ported heads and ported intake. The heads flow 268cfm at .600 intake, and 203 cfm exhaust at .600. The guy that had the heads before me ran a 236/242 cam and was running 11.7s in the 1/4. Should I use this cam or something else? thanks (ps- i think my springs are good to .600)
Old Jan 19, 2008 | 11:55 PM
slomarao's Avatar
depends if you handle that cam, its going to be big for 355.
Old Jan 20, 2008 | 12:13 AM
johnnyb's Avatar
ill probably end up going the custom route, but i dont really know what kind of numbers im looking for. ??
Old Jan 20, 2008 | 01:00 PM
johnnyb's Avatar
any ideas?
Old Jan 21, 2008 | 08:19 PM
seawolf06's Avatar
I had a 236/242 xfi cam in my 355 setup and it ran great. The heads were the limiting factor and it made 372 rwhp at 6100 RPM. I suggest going with a shorter LSA than shelf cams if you can. Check out the voodoo lineup from Lunati. Those cams are badass.
Old Jan 24, 2008 | 09:02 PM
SiDeWaYZz28's Avatar
yes the springs that are on the heads are comp 987 good to 600
LeftoverChinese
Jan 14, 2024 03:03 PM
oldschool
Feb 9, 2016 09:21 PM
blac94Z
Feb 18, 2015 11:36 AM
InfernalVortex
Jan 17, 2015 09:35 AM
