Running 1.7 Roller Rockers with an XFI hydraulic roller cam?
any spring recommendations? It will be under .650 lift even with the 1.7. if this will/has worked I would be using quality nsa rockers. anyone doing this with a high lift cam? worth it? the heads I want to put on flow 292@ .650 lift
Who recommended the cam to you? I know that the xfi lobes are very aggressive lobes with just 1.6RR. I don't think there are any springs that will work with that setup, not to mention your valve geometry will be off.
oldschool
Feb 9, 2016 09:21 PM
