Running 1.7 Roller Rockers with an XFI hydraulic roller cam?
Old Jan 23, 2008 | 09:12 AM
1LESSZ28's Avatar
any spring recommendations? It will be under .650 lift even with the 1.7. if this will/has worked I would be using quality nsa rockers. anyone doing this with a high lift cam? worth it? the heads I want to put on flow 292@ .650 lift
Old Jan 23, 2008 | 10:56 AM
rich152's Avatar
I am running a 1.7 NSA rocker on a small basecirlce custom grind with .624/.628 lift. I have not experienced any issues as of yet.
Old Jan 23, 2008 | 01:37 PM
1LESSZ28's Avatar
what springs/ installed height? is this a hyrdraulic cam?
Old Jan 23, 2008 | 02:13 PM
rich152's Avatar
Springs are pac 1218's, stock height. And yes it is a very aggressive xfi lobe with a HR, plus its a small base circle.
Old Jan 23, 2008 | 02:52 PM
seawolf06's Avatar
Who recommended the cam to you? I know that the xfi lobes are very aggressive lobes with just 1.6RR. I don't think there are any springs that will work with that setup, not to mention your valve geometry will be off.
LeftoverChinese
Jan 14, 2024 03:03 PM
oldschool
Feb 9, 2016 09:21 PM
alliance12364
Mar 6, 2015 04:39 PM
1775.Z28
Jan 11, 2015 10:51 AM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
