Freescan question.
Freescan question.
I did a scan and one of the things listed says " start temperarure ". Mine says 32 degrees F when i put the key in and it starts reading data. It stays that way the whole time. Anyone know what this is for and why it reads just above freezing when it 90+ here?
Thats how freescan behaves with our pcms, freescan supports multiple pcms not just fbody pcms I suspect that reading doesnt exist in our pcm and it ends up with the default value of 32 degrees F. (should be 0 C if you leave it in centrigate mode which is the default reading mode so it would naturally default to a value of 0 for a non existant reading) I could be wrong but i've never bothered to check the code.
Line 485 of /freescan/protocols/src/GM1994CamaroZ28Parser.cpp in the function void CGM1994CamaroZ28Parser::ParseMode1_0(unsigned char* buffer, int len) which "Translates the incoming data stream as Mode 1 Msg 0"
m_pSupervisor->m_fStartWaterTemp = 0.0;
Looks to me mrmint is talking about the start temperature reading, 94 bad a z28 is saying the 32 degrees is from him doing the resister mod.
Latronaxe
Jul 20, 2015 12:00 PM
