Freescan question.
Old Jul 18, 2007 | 08:01 PM
mrmint69's Avatar
Freescan question.
I did a scan and one of the things listed says " start temperarure ". Mine says 32 degrees F when i put the key in and it starts reading data. It stays that way the whole time. Anyone know what this is for and why it reads just above freezing when it 90+ here?
Old Jul 18, 2007 | 08:12 PM
'94 Bad A Z28's Avatar
Your car probably has a resistor in the IAT sensor to trick the computer in to thinking that it is taking in colder air than it is. Are you the first owner? If not this is very possible.
Old Jul 18, 2007 | 08:39 PM
mrmint69's Avatar
It use to have the resistor but i pulled it out when it didn't make an more power at all.
Old Jul 18, 2007 | 08:50 PM
LiENUS's Avatar
Thats how freescan behaves with our pcms, freescan supports multiple pcms not just fbody pcms I suspect that reading doesnt exist in our pcm and it ends up with the default value of 32 degrees F. (should be 0 C if you leave it in centrigate mode which is the default reading mode so it would naturally default to a value of 0 for a non existant reading) I could be wrong but i've never bothered to check the code.
Old Jul 19, 2007 | 02:06 PM
NJ-LE's Avatar
mrmint69:
Is it possible that when you removed the resistor that a connector pin got pulled back or bent in a way that left the IAT signal either grounded out or open and the ECU is forced to use a safe default?
Old Jul 19, 2007 | 03:13 PM
LiENUS's Avatar
Originally Posted by NJ-LE
mrmint69:
You guys are over analyzing waay too much. I told you why it was that way already, heres proof.
Line 485 of /freescan/protocols/src/GM1994CamaroZ28Parser.cpp in the function void CGM1994CamaroZ28Parser::ParseMode1_0(unsigned char* buffer, int len) which "Translates the incoming data stream as Mode 1 Msg 0"
m_pSupervisor->m_fStartWaterTemp = 0.0;
IT never even attempts to fetch the coolant start temp, it just sets it to the default value of 0.0 degrees Celsius which in Fahrenheit is... 32.
Old Jul 19, 2007 | 05:56 PM
NJ-LE's Avatar
LiENUS:
That may be true about the "coolant start temp" but I believe "mrmint69" and "'94 Bad A Z28" certainly is writing about the Inlet Air Temp (IAT) sensor reading.
Old Jul 19, 2007 | 06:14 PM
LiENUS's Avatar
LiENUS:
Looks to me mrmint is talking about the start temperature reading, 94 bad a z28 is saying the 32 degrees is from him doing the resister mod.
Old Jul 19, 2007 | 06:45 PM
TobyZ28's Avatar
Toss us a screenshot by pressing "print screen" on the keyboard and pasting it into something like MS paint in windows.
Latronaxe
Jul 20, 2015 12:00 PM
timmy39120
May 2, 2015 05:12 PM
JeffK95Z
Nov 13, 2002 12:50 AM
NONO5.0
Sep 27, 2002 03:49 PM
Dave 96TA
Sep 24, 2002 04:10 PM
