think my rockers were too tight, consequences?
Old Jun 15, 2007 | 05:07 PM
dueno's Avatar
I've been running my GM performance parts 1.6 roller rockers that I got with my hotcam kit for about 1500 miles now. However I tightened them to approx 3/4 turn past 0 lash. As brought up in my older thread here (http://web.camaross.com/forums/showthread.php?t=526462) this might have been too tight. However I used shbox's guide and also read over the paperwork that came with the RR and both said that 3/4 SHOULD be fine. The car runs absoutely perfect, and there is no unusal valvetrain noise so I didn't think anything was wrong. However after racing from a roll multiple times against a bolt on 350z (intake, headers, exhaust) and a 270 awhp WRX and running DEAD even, I'm beginning to think my car is lacking power somewhere. I'm at a loss now at what I should tighten things to. Please help me out. My current mods are in my sig. Thanks.
Old Jun 15, 2007 | 06:04 PM
1racerdude's Avatar
If you had true TDC on each cyl. they should be fine but you can back them off to 1/8 turn if ya want.
I would check my tune.
Old Jun 15, 2007 | 06:21 PM
91RSLT1's Avatar
Like 1racerdude said you should be fine, you could always re-lash them. As far as consequences go damaged/collaped lifter(s), possibly bent pushrods. I tighted mine to much which collaped a lifter, which broke a push rod in half. Oh and one of my crane golds got chewed up pretty bad. I put a new pushrod in and it got bent like a banana. Put in a new lifter and pushrod, no problems. This only happened on the intake side of the #1 cylinder.
Old Jun 15, 2007 | 07:46 PM
dueno's Avatar
Yah, I was pretty close to TDC. I think I'm gonna go in and just relash them all to 1/2 turn past 0 lash. I don't have a tune for my new parts yet, and thats probably where alot of my hp is.
Old Jun 16, 2007 | 11:08 AM
stereomandan's Avatar
1/2 turn is optimal if you still have the stock 3/8" diameter studs.
Dan
Old Jun 16, 2007 | 05:38 PM
dueno's Avatar
Yah I still have the stock studs. Also, everything in my valvetrain is from the hotcam kit that I bought so it fit right in stock.
Old Jun 16, 2007 | 05:58 PM
exgmguy's Avatar
If you have them adjusted a little too tight the valves will hang open slightly. It will cost you power that you will especially notice on the top end.
Old Jun 16, 2007 | 07:29 PM
dueno's Avatar
Exactly what I was wanting to hear. I'm pretty sure with my mods I should be able to pull on 350z's from a roll atleast, after I adjust my rockers lol.
13qtr
Oct 28, 2016 08:11 PM
IndyZman
Oct 22, 2015 02:17 PM
95chwagon
Oct 16, 2015 12:24 PM
football4life
Oct 4, 2015 07:48 AM
9t4lt4z28
Oct 2, 2015 10:28 AM
