Small oil leak after new opti and ewp install...
Hey all, I just noticed a little drip of oil on my garage floor when I pulled my car out. I recently changed the opti as well as put an electric water pump in. After a checkover, I can't find any oil anhywhere on the engine, even the bottom of it. Got any ideas before I dish out some more green on this money pit??? Much appreciated
I've got the same problem, small drip every once in a while. Even after a new timing cover gasket, front crank, opti, and water pump seals, and a new opti, I still have this small leak. It looks like it leaks from the front crank seal on mine, but I haven't bothered to mess with it because my car finally runs decent and I don't want to mess with it. Hope you figure it out, cuz I'm curious as to what it is. Good luck!
Magenta_Hearts
Mar 29, 2017 08:54 PM
I haven't found any more oil on the floor of the garage yet; lets just hope it stays that way.
