Car cuts out at wot usually when above 3000rpm, no ses. Just replaced opti.
Old Feb 22, 2007 | 10:14 PM
djm_e22's Avatar
Sometimes but not always if I go above 3000rpm at wide open throttle, it seems as if my ignition just cuts off for a split second and I sometimes get a backfire. It never or at least not yet has died on me, just simply cuts off for a second. I just replaced the opti to see if that was it and it is still doing it. Also when it does this I wait to see if a SES comes on but it doesn't. Thanks for any help.
Old Feb 23, 2007 | 05:05 AM
Guest47904's Avatar
Guest
Ignition switch???? Do you have a large bundle of keys? Does it seem as though other electrical items are cutting out as well?
Old Feb 23, 2007 | 11:10 AM
jsetzer's Avatar
What opti did you put back on? Line it up right? Plug wires in the right spot?
A crossed wire will make it run like a bad opti. runs but pops and misses etc.
Age of plugs / wires? I pretty much swap plugs anytime I touch the ignition because they are so cheap.
Old Feb 23, 2007 | 11:19 AM
BUBBA's Avatar
Make sure your ignition system is well grouded, especially the MSD. E Ignitions should be grounded to block or at least somewhere where you can get a good ground or you might get what you are experiencing at higher revs. JMHP
cmdeshon
Dec 12, 2014 10:51 PM
Dec 4, 2014 11:56 AM
USAirman93
Nov 24, 2014 03:37 PM
supercharged94Z28
Feb 24, 2003 10:22 PM
CobraEatr
Jul 29, 2002 11:46 AM
