294hp/310lb rwhp and tq dyno??
294hp/310lb rwhp and tq on a dyno, these are the numbers that my 97 m6 put down the rear wheels today. i was kinda dissapointed i thought that i was going to break atleast 300hp. Any body think that this is a wierd output for the mods that i have. the techs at the dyno shop said that i could benifit by getting some long tubes and a cut out cat back system. my signature has a list of all my mods, im running a stock 3" system that came on my 97SS and running some shorty bbk headers. any one have any recommendations on what i could do to get my numbers up and whether or not this is about right for what i have done so far.
Hotcam + RR + tune + no other mods is typically higher than that.
For instance:
http://www.wku.edu/~nathan.plemons/h..._corvette.html
So I'd say you have some missing HP.
For instance:
What rpm did it peak at? Are your plugs and wires in good shape? What kind of fuel were you using, What were the conditions or were those numbers corrected? Yes, the numbers are low and if you want help figuring out why details are needed. If you could scan and post the dyno graphs, that would also be a big help. Besdies plugs and wires, the commonest reason for low numbers is knock retard.
Rich
Rich
here's the dyno sheet that was requested, the increase looks kinda shay from 4k and up, what could that be from, i have a rebuilt opti in there and stock wires with my msd could that be it. the air fuel ration is kinda hard to read but does it look lean?
http://s169.photobucket.com/albums/u...ewtechdyno.jpg
