294hp/310lb rwhp and tq dyno??
Old Jan 31, 2007 | 07:41 AM
  #16
buzz12586's Avatar
Wow yea looks like it was running pretty lean up top. Might wanna get that fixed.
Old Jan 31, 2007 | 09:00 AM
  #17
Z-RATED94's Avatar
If that A/F ratio is correct I can't believe the dyno operator didn't abort the pull.
Old Jan 31, 2007 | 10:46 AM
  #18
roguedriver's Avatar
What he said!!! Thats way too lean. That could be why your curve is all choppy looking too. Do you know what your fuel pressure is also while making the runs? It would appear you have some issues to address. It will make more power then that. I wouldn't hammer on the car for now though until you get that A/F down first.
Ken R.
Old Jan 31, 2007 | 05:56 PM
  #19
sbs's Avatar
sbs
In addition to scary AFR, it should pull to at least 6k. Possible valvetrain problems?
Old Jan 31, 2007 | 08:24 PM
  #20
SS RRR's Avatar
Isn't the target A/F for LT1's 12.7? The lower the number the richer the condition. Not the other way around. That power curve is peaking way too early though.
Old Jan 31, 2007 | 08:30 PM
  #21
ZX636RIDER03's Avatar
i did a fuel pressure test today and when i got on it fuel pressure would drop gradually to 20psi as rpms would climb, so ive been told it was the fuel pump. any one have any recomendations on what brand may work the best? i also have hard starts, and the valve train might need some adjustment, for the rockers i heard 1/4 turn is plenty from 0 lash im currently on almost a full turn off of 0.
95chwagon
Oct 16, 2015 12:24 PM
fift5
11
Oct 1, 2015 10:31 AM
Z Power
Sep 19, 2015 11:19 PM
DelSoto
Sep 19, 2015 05:31 AM
94ZinEdgewater
Sep 8, 2015 09:55 PM
