The problem with the MSD Opti-units.
Old Jan 29, 2007 | 12:36 AM
Rage's Avatar
There have been reports of the the MSD Opti-spark units having flaws such as the rotor rubing and wat not. I have one of these that I installed on my LT1 before putting it in my IROC. Would this cause my car not to start? The car cranks, sputters and dies. Let me know what you think.
Old Jan 29, 2007 | 08:40 AM
Chris 96 WS6's Avatar
I think it is highly unlikely. It is more likely that something is wrong with the install, like the drive pin isn't in the right slot, or the plug wires aren't in the right order, etc.
Old Jan 29, 2007 | 09:03 AM
WhiteCamaro88's Avatar
Chris WS6
Nice page bro, i like the rims on the t/a where did you get em ???
What size tires / what tires you have on em , im looking into getting the same combo
Old Jan 29, 2007 | 11:30 AM
2000GTP's Avatar
If it was working fine on one car and all of the sudden doesn't work when swapping it to another, I would double check your installation.
Old May 1, 2007 | 12:43 PM
gelbza's Avatar
Actually this is entirely possible. I installed mine in February, and last week my car died at a stop sign. The cause was lack of spark to the plugs, although it was reaching the opti. Upon pulling off the old opti I found it to be covered in red dust from the rotor rubbing, thus blocking both the contacts and the optical sensor.
Old May 1, 2007 | 01:00 PM
Z28SORR's Avatar
The way this reads I can't tell if your talking about your original Opti or you MSD one. Also have you up dated to vented with the new MSD.
Old May 1, 2007 | 01:25 PM
OutKast's Avatar
stock opti is not red inside, sounds like the MSD rotor came loose
Old May 1, 2007 | 02:40 PM
gelbza's Avatar
True, I guess I wasn't very clear. I meant after I pulled off the MSD opti cover this time I found the red dust. And yes, it's been vented.
OutKast: I'm fairly certain the rotor wasn't loose as when I pulled it off I had to work at it a little to free the rotor from the shaft (I have no idea what it's called) it's sticks into. Also, no pinching of the o-ring that I can tell as MSD has previously claimed causes this. I'm sending it in to them and waiting to see what they say. If anyone wants, I can post pictures later.
Old May 1, 2007 | 02:49 PM
maybe2fast's Avatar
I have the MSD cap and rotor. Runs awesome and installed really nicely...
Old May 1, 2007 | 08:35 PM
96redrum's Avatar
Had the same problem after i put in the cap and rotor in my car along with wires and new spark plugs , same thing though had the red dust but didn't effect the way the car drove after every thing was redone, are you sure the dowel is in the right spot, also my car didn't start after everything was lined up right because the spark plugs were fowled out so bad, had the NGK TR55 and are junk after they get flooded. put new plugs in and started right up. hope this help
Old May 1, 2007 | 11:03 PM
gelbza's Avatar
I replaced the plugs at the same time as the opti in Feb, plus it was a GM shop that told me the spark wasn't reaching the plugs. Only thing I can figure is that it's the dust as everything else was aligned perfectly.
RUENUF
May 25, 2016 08:10 PM
mr28
Apr 20, 2016 05:44 PM
RUENUF
Mar 13, 2016 03:39 PM
thenewkid
Apr 12, 2015 07:42 PM
