LT1 with Carb
If going carb you are missing a BIG part of the advantages of using an LT1. If you have not purchased yet consider starting with a gen 1 motor should be cheaper and will have a wider selection of carbed intake to choose from.
I have a doner car http://i3.photobucket.com/albums/y90...icture0301.jpg
If you're going to run the LT1, go with the EFI and factory PCM. That is what an LT is all about “EFI.” If you don't want all the LT1 high-tech "bells and whistles" you should find a 1st Gen small block engine. The carb and HEI would just be down-grading the LT to basically a 1st Gen engine.
Was anyone killed in the donor car? That wreck looks really bad!
WD
WD
