oil pressure sensor angle fitting
Old Jan 29, 2007 | 12:10 PM
Wims97T/A's Avatar
I am in the middle of replacing the intake manifold gaskets and replacing the oilpressure sensor.
I was wondering if i have to take the angle fittings out of the block and reseal them again to be sure there is no leakage from them.
And what kind of sealant should i use for the sensor and mabey the fittings.
Old Jan 29, 2007 | 01:36 PM
You don't have to remove the angle fittings. It's up to you if you want or need to because of leakage. Use pipe dope or thread sealant from a tube, not teflon tape.
Old Jan 29, 2007 | 01:50 PM
2tight's Avatar
whats wrong with telfon tape?
Old Jan 29, 2007 | 03:37 PM
Wims97T/A's Avatar
O.K. thanks.
I will now wat to do next weekend,and this is the most easy part.
Old Jan 29, 2007 | 04:13 PM
The oil will dissolve it. It's ok for non-oil exposure applications.
HectorM52
Jul 30, 2017 11:46 AM
linz
3rd Gen / L98 Engine Tech
Oct 22, 2015 07:59 AM
phoenix95
Jan 8, 2015 02:44 PM
phoenix95
Jan 8, 2015 09:14 AM
Jul 4, 2005 05:00 PM
