Here are the specs.. help w/rpm range
Old Jan 25, 2007 | 09:19 PM
lt1 kenobi's Avatar
Hey guys... here is a cam I had given to me... to use... I'll be using it w/ported heads... What I'm trying to figure out is wether or not its gonna turn too many rpms to make its power for me to use spray as well... in other words.. will it make power above 6500 or so... b/c I'd like to not have to turn that high w/spray on stock bottom end....
268/277 548/564 108cl solid roller
Thanks guys
Old Jan 26, 2007 | 03:10 AM
lt1 kenobi's Avatar
I know there are some experts in here.... anyone????
Old Jan 26, 2007 | 03:50 AM
bdc95ta's Avatar
What size motor, stock ported heads?
Old Jan 26, 2007 | 06:39 AM
toby's Avatar
i am assuming those duration numbers are advertised. if so that should be a very good street cam for a stock bottom 350.
Old Jan 26, 2007 | 08:57 AM
rskrause's Avatar
Moderator
It's a hydraulic roller? What is the displacement? What is the CR? What is the duration at 0.050"?
Rich
Old Jan 26, 2007 | 10:17 AM
lt1 kenobi's Avatar
Everything you guys have asked for is in the first post!.. With the exception of duration at .050 which is 240/246. Ported heads...
Old Jan 26, 2007 | 10:51 AM
street demon2k3's Avatar
Damn man, if your running a stock bottom end with that big cam it would have to rev pretty high to make power. the cc306 and gm847 are a little smaller and have to be revved over 6500rpm, then on spray it should put a little more stress on the bottom end. i believe there are better alternatives cam wise like the 224/236 114LSA. just for comparison the cc306 is 230/244 and the gm847 is 234/242 112LSa also, you might want to try maybe a custom grind or a smaller shelf cam on a 114LSA.
Or re-ring/re-bearing the bottom end along with some forged pistons and that should give you more peace of mind.
Old Jan 26, 2007 | 10:57 AM
speed_demon24's Avatar
Solid roller cams are completly different than hydrolic, I would call up a shop and see what they have to say, most people on here have no experience with solid rollers.
Old Jan 26, 2007 | 12:31 PM
toby's Avatar
that cam should peak at 6500 and shifted at about 6800.
Old Jan 26, 2007 | 01:22 PM
dmoss69's Avatar
Cam
Yeah, the GM847 hydro that I had would turn up to 7000 easy, and your cam is bigger than the 847.
lt1 kenobi: You have a PM also!
D Moss
Old Jan 26, 2007 | 01:27 PM
rskrause's Avatar
Moderator
Peak hp ~6,500
Rich
Old Jan 26, 2007 | 11:00 PM
lt1 kenobi's Avatar
Hmmm guess I'll have to wait and go with a hydraulic roller .. something smaller... the cam is free so thats why I was wondering... But I don't think 6800 shifts and 125 shot are gonna do well on the stock bottom end
Old Jan 27, 2007 | 04:39 AM
rskrause's Avatar
Moderator
You would lose very little shifting 500rpm lower. Still, it's a big cam.
rich
drt
Sep 27, 2015 04:39 PM
SEOJustin
Sep 24, 2015 04:39 PM
plattted
9
Sep 20, 2015 11:23 AM
NewsBot
Sep 14, 2015 02:02 AM
Aug 7, 2015 08:52 AM
