Oil pressure...
mines at 60psi warm at idle
i have the mellings hig volume pump the big acdelco filter and am runnig 5w30 regular valvoline
motor is rebuilt with stock everything just new bearings and rings has about 2500 miles on it
Damn! That seems a bit on the high side. Mine runs about 20 psi at a warm idle.
Mine runs 25 to 30 when full hot with 100k on the clock. It used to dip to just above 10 lbs until I changed my pressure sender behind the intake.
If you do a search on this topic you will find threads with many more answers.
if i let the cra idle to long it will bottom out and check gauge come on. Mine is less than 20psi. 98k miles
When under hood temps get high is when the gauge drops off. Other wise it's always just under 20.
oh 4qts 10w-30 mobile 1 supersyn and 1 qt of lucas
RX Speed Works
Jul 24, 2015 02:25 PM
