Oil pressure...
Old Dec 24, 2006 | 01:38 AM
LT1Squirrel's Avatar
Oil pressure...
Whats your oil pressure at idle fully warmed up?...and when you reply please list miles, stock/nonstock oil pump, oil, and filter used
Eric
Old Dec 24, 2006 | 01:59 AM
FryedClutch's Avatar
mines at 60psi warm at idle
i have the mellings hig volume pump the big acdelco filter and am runnig 5w30 regular valvoline
motor is rebuilt with stock everything just new bearings and rings has about 2500 miles on it
Old Dec 24, 2006 | 04:25 AM
droptop z's Avatar
Damn! That seems a bit on the high side. Mine runs about 20 psi at a warm idle.
Old Dec 24, 2006 | 09:31 AM
01Z's Avatar
01Z
Mine runs 25 to 30 when full hot with 100k on the clock. It used to dip to just above 10 lbs until I changed my pressure sender behind the intake.
If you do a search on this topic you will find threads with many more answers.
Old Dec 24, 2006 | 10:22 AM
DrewHMS97SS's Avatar
I run 40 psi on a new meling, it drops to maybe 35 warm.
Old Dec 24, 2006 | 02:13 PM
2000GTP's Avatar
Mine is anywhere from 18-23 at idle when warmed up.
Old Dec 25, 2006 | 08:53 PM
dre2013's Avatar
about 40 at warm idle...my idle is a little high though, right around 1050rpms
Old Dec 29, 2006 | 11:58 AM
DAFAIC's Avatar
if i let the cra idle to long it will bottom out and check gauge come on. Mine is less than 20psi. 98k miles
When under hood temps get high is when the gauge drops off. Other wise it's always just under 20.
oh 4qts 10w-30 mobile 1 supersyn and 1 qt of lucas
Old Dec 29, 2006 | 12:59 PM
jeff_is_sexy's Avatar
1,500 miles on a rebuild with a Melling high volume, 8 pounds warm... My sender is bad; it reads 50-60 pounds at idle when it's cold.
Old Dec 29, 2006 | 01:08 PM
JasonK94Z's Avatar
~20 lbs when hot at idle. I have 89k miles. I use the bigger sized Wix filter and 20w-30 Mobile 1 oil.
RX Speed Works
Jul 24, 2015 02:25 PM
big_mac421
Jul 13, 2015 03:48 PM
jl1ne
Jul 7, 2015 08:38 PM
streetbad
Advanced Tech
Jul 5, 2015 10:40 PM
SergheiS
Jul 5, 2015 03:27 AM
