Tuning a future LE2 setup
When I get the money, I'm going to buy the LE2 heads and probably some new fuel injectors, but I wanted to wait and buy the cam later when I have the money to have it installed right away. I'm also about to buy LT1 Edit to tune my car and I was wondering if this program will have everything I need to tune with the LE2 setup? Also, I would imagine it's safe to run the car between the head and cam install with the tune setup for heads only but I just wanted to make sure because I'll be new to the whole tuning thing.
I agree about waiting until you have all your pieces to install. But if you must do it piece-by-piece, you should go with a cam first. You will see a greater increase in performance with a cam vs. heads on the stock cam. The stock cam will not put the LE2 heads to their full potential, vs. a after market cam.
Ok, I was planning on doing the heads first because I can do those on my own, but the cam I will have to take to a shop. But I guess I'll get the LT1 Edit awhile, tune it now, since I just installed a whole bunch of bolt ons, then retune it only one more time after the heads and cam are both in. Does that sound like a better idea?
My plan was to do the heads myself without removing the motor, then taking the cam to the shop. I don't really want to mess with anything near the waterpump or opti again, since I just got done replacing opti a couple months back. It was a pain to in my garage and I'd like to keep that kind of stuff to a bare minimum. But I didn't realize the heads would be all that tough to get out with the engine in. So now I'm leaning towards just taking both H/C to the shop and letting them deal with the whole thing.
But yea, I know the tuning can get really confusing and I'm new to it so that's why I was going to work with it as is, before H/C, then hopefully learn all about it before doing anything else. It's not like I'm going through this in a matter of weeks, it will be many months between tuning and H/C that I'm going to ask questions and get to know the tuning program before trying anything big.
Thanks for the help so far
IgorT.455/406
Mar 12, 2015 03:39 AM
Bignasty85
Mar 3, 2015 04:05 PM
