Whats the key to getting the waterpump shaft seal on?
Whats the key to getting the wp shaft seal on without damaging the seal?
I put the first one on with the timing cover already installed and the inner black seal got torn up from the sharp lip on the shaft .
Do all this very carefully and no damage will happen.
Chop a "Mark-aLot" magic marker tube in 1/2 and use that as your seal guide/bushing to slide the seal over the water pump shaft and hopefully it wont rip.
Even a new seal might rip from being "old new stock" . That seal is so easy to rip and it wont stretch when it gets old.
Karl
Karl
Thanks for the ideas. Everything I had that was cone shaped was too thick, if it fit over the shaft then it would not fit thru the seal, but I used a small funnel end and oiled up the seal and pushed it down the funnel cone as far as it would go, let it sit for a few minutes and pulled the seal off the funnel end and it kept the seal spread apart enough it slipped right on to the shaft.
Victor Lamb
Aug 26, 2017 02:52 PM
carguyshu
Jan 22, 2017 11:19 AM
Dan_the_ManZ28
Feb 21, 2015 02:01 PM
