Coolant Leak - water pump?
I've got a coolant leak in my new car. I noticed it was up around 240* while driving back home from AutoZone so being **** I turned the heat on and knocked it down to 205-210*
I realilize LT1's run hot and the temp gauge reads hot as it's in the ds head wheras the pcm thermomater is at the water pump. Anyways, I noticed it iwas leaking tonight... Looked underneath and it apperars to be coming from behind the crank pulley (it's dark can't see much)
So anyway, decided not to drive the car, driving my other car tomorrow. Anything I can do? Probably won't get looked at till Saturday-Tuesdayish.
Should I drain the coolant via the radiator petcock?
240 is pretty high. If the coolant is leaking out of the water pump weep hole, then you will indeed need to replace it. If you are leaking coolant and it is running hot, I would hold off on driving it unless you want to replace more then just the waterpump.
heh, operating temperature is probably around 190-210. High fan doesn't kick on till 236.
Finally got a chance to look at it in day light.
http://picsorban.com/upload/img_0457.jpg
http://picsorban.com/upload/img_0458.jpg
http://picsorban.com/upload/img_0459.jpg
you can buy an electric one for less than that. mine just went out and i bought the summit brand ewp. works great. not a real hard deal to do, besides pressing out the old gear. but can be done in a day no problem.
Magenta_Hearts
Mar 29, 2017 08:54 PM
Magenta_Hearts
Mar 25, 2015 10:24 AM
Sandersen511
Jan 13, 2015 03:49 PM
