Coolant Leak - water pump?
Old Nov 14, 2006 | 09:02 PM
6SpdLT1Z's Avatar
I've got a coolant leak in my new car. I noticed it was up around 240* while driving back home from AutoZone so being **** I turned the heat on and knocked it down to 205-210*
I realilize LT1's run hot and the temp gauge reads hot as it's in the ds head wheras the pcm thermomater is at the water pump. Anyways, I noticed it iwas leaking tonight... Looked underneath and it apperars to be coming from behind the crank pulley (it's dark can't see much)
So anyway, decided not to drive the car, driving my other car tomorrow. Anything I can do? Probably won't get looked at till Saturday-Tuesdayish.
Should I drain the coolant via the radiator petcock?
Old Nov 14, 2006 | 09:03 PM
BadBowLT1's Avatar
change the waterpump before it kills the opti
Old Nov 15, 2006 | 07:09 AM
Javier97Z28's Avatar
Moderator
Sounds like the waterpump is on the way out.
LT1's don't "run hot"
Old Nov 15, 2006 | 10:19 AM
2000GTP's Avatar
240 is pretty high. If the coolant is leaking out of the water pump weep hole, then you will indeed need to replace it. If you are leaking coolant and it is running hot, I would hold off on driving it unless you want to replace more then just the waterpump.
Old Nov 15, 2006 | 09:45 PM
6SpdLT1Z's Avatar
I've been driving another car, should I be concerned about it leaking on the opti while it is sitting? I was thinking about putting a rag over it or draining the coolant.
heh, operating temperature is probably around 190-210. High fan doesn't kick on till 236.
Old Nov 16, 2006 | 02:10 PM
6SpdLT1Z's Avatar
Finally got a chance to look at it in day light.
http://picsorban.com/upload/img_0457.jpg
http://picsorban.com/upload/img_0458.jpg
http://picsorban.com/upload/img_0459.jpg
Old Nov 16, 2006 | 02:31 PM
JoeliusZ28's Avatar
bite the bullet before your biting an opti round too. its toast. personally I think youre lucky thats the biggest problem youve run into buying a car over ebay.
Old Nov 16, 2006 | 02:45 PM
Moderator
$100 fix and can be swapped in 30 minutes. Just get her fixed up real quick and call it a day.
All you need is a catchpan and some 9/16" sockets.
Old Nov 16, 2006 | 09:45 PM
6SpdLT1Z's Avatar
GM Waterpump is about $200.
Old Nov 16, 2006 | 09:53 PM
83tpi_3rd-gen(sri)'s Avatar
you can buy an electric one for less than that. mine just went out and i bought the summit brand ewp. works great. not a real hard deal to do, besides pressing out the old gear. but can be done in a day no problem.
Magenta_Hearts
Mar 29, 2017 08:54 PM
Magenta_Hearts
Mar 25, 2015 10:24 AM
94Z28LS1toLT1
Jan 15, 2015 07:18 PM
Sandersen511
Jan 13, 2015 03:49 PM
pologreen97z
Dec 2, 2014 10:42 AM
