Help with BBK 58mm TB
I'm swapping out the stocker for the 58mm and I'm all done but I can't figure out how to run the throttle cable. Pics would be super helpful or just a clear explanation.
No pics but...
Open the throttle all the way to put the pinhole for the throttle cable closer to the cable. The end of the cable has a little push pin, just line that up with the hole, then lay the cable into it's run. That's it...
Good luck
Jonota
Good luck
Jonota
RUENUF
Mar 13, 2016 03:37 PM
