Help with BBK 58mm TB
Old Nov 7, 2006 | 06:30 PM
ChazGotACAmaro's Avatar
I'm swapping out the stocker for the 58mm and I'm all done but I can't figure out how to run the throttle cable. Pics would be super helpful or just a clear explanation.
Old Nov 8, 2006 | 02:28 AM
jonota's Avatar
No pics but...
Open the throttle all the way to put the pinhole for the throttle cable closer to the cable. The end of the cable has a little push pin, just line that up with the hole, then lay the cable into it's run. That's it...
Good luck
Jonota
RUENUF
Mar 13, 2016 03:37 PM
truecontr3
Oct 11, 2015 09:30 AM
95craz28
11
Sep 12, 2015 07:47 AM
95z_28_camaro_4_Ivan
Aug 25, 2015 03:59 PM
alphaauto
Jul 26, 2015 04:40 PM
