Speed Density Tune on 95 LT1?
Old Nov 1, 2006 | 11:49 AM
DGAF420's Avatar
I recently had someone break into my car and steal a ton of parts off of it that were laying in the engine bay One of those things was my MAF. Can I have a mail order tune place tune my car for no MAF? If so, how does it affect the drivabilty? Thanks, Brad
Old Nov 1, 2006 | 11:57 AM
DGAF420's Avatar
If it matters there is now some more info on my car in my sig.
Old Nov 1, 2006 | 12:30 PM
edunegan95's Avatar
i heard you can do a speed density tune on lt1 but you can only tune for that day if the weather changes youll have to change the tune or live with a bad running car till cana get a sensor
Old Nov 1, 2006 | 12:58 PM
edunegan95's Avatar
Lt1 Maf
good cond. no screen
from a 95 Formula
$40 shipped
__________________
Southeast Muscle Car Club found this might ceck on it and keep looking in the parts for sale
Old Nov 1, 2006 | 03:19 PM
sbs's Avatar
sbs
Yes it's easy to do, and 92-93 LT1s were SD from the factory. But a MAF is a lot cheaper than a tune.
Old Nov 1, 2006 | 03:31 PM
cjmatt's Avatar
it wont be off that much, but a tune at -15 degrees vs 104 degrees will be off, itll still run fine at both though, just not dead nuts on.
Old Nov 1, 2006 | 04:08 PM
DGAF420's Avatar
Well the price of the tune dosent matter because I need one anyways for my cam change. How about through winter...this is gonna be my semi daily driver if I can get it finised before it gets to cold to work on it.
Old Nov 1, 2006 | 05:22 PM
Speed density has the same accuracy as MAF, as long as you get the VE tables right, and don't change anything. The weather will not affect it, because the "density" part of speed density fully accounts for the changes in temperature and barometric pressure.
The only difference between speed-density and MAF is the fact that the MAF sensor measure mass air flow directly, while speed density has to calculate the mass air flow from the rpm, VE, IAT and MAP. As long as you don't make a change that alters volumetric efficiency, you don't need to change the speed-density tune.
I wouldn't switch to speed-density just because someone stole the MAF sensor. Won't your insurance pay for a new one?
Old Nov 1, 2006 | 08:22 PM
Brent94Z's Avatar
Super Moderator
Wouldn't it be cheaper and easier just to buy a used MAF sensor? I want to say I picked up a used one for like $30 or $40 a while back.
Old Nov 2, 2006 | 12:22 AM
DGAF420's Avatar
No Insurance wont pay for it. I had tons stolen from the car, cd player, amp, shift boot, shift ****, dash fuse door, dash radio trim panel, pcm, radiator, ac condensor, maf, 1le elbow, k&n CAI, my valve covers which had my 1.6 roller rockers in them, opti, and other stuff I forgot about. Oh and as to wether spending $30-$40 on a used MAF verses $0 in a MAF removal on my tune that I already have to have done for my cam and other things I installed. So yes spending $0, assuming that the MAF removal is an option on PCMForless's or MadZ28's tunes. Because I also really want to make my own CAI out of curved 3 inch pipe that I will paint body color (white), and just to strait to a K&N filter behind the front drivers tire. Thanks for everyones info.
Old Nov 2, 2006 | 09:46 AM
Sweetred95ta's Avatar
I run a speed density tune on my car. I wouldn't necessarily recommend it unless you have the tuning software and can do it yourself. The reason is because you need to make multiple logs of the car and use VEMaster to get the VE tables right. If you already have the stuff to make logs of the car, you might as well spend the extra $100 and get TunerCAT and do the tuning yourself. Also, a wideband setup would help a ton for WOT.
So, the answer is yes, you can run SD.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
DirtyDaveW
Dec 1, 2016 05:37 PM
Jul 4, 2005 05:00 PM
JSK333
Sep 9, 2002 10:33 PM
