Guaging interest: Eagle 4340 357 kit
Old Dec 1, 2005 | 04:33 PM
jsetzer's Avatar
4340 3.5" Crank Eagle
Forged SRP Pistons .030 over, plasma rings
Eagle H beams 5.7"
Has some Clevite77 Bearings
Summit sells these for $1900ish (well the 355 version)
Everything new in box, I would rather pass the savings on than pay 15% restocking + shipping to return. You would spend $1600 piecing it together without bearings/rings.
Would anyone be interested in it for say $1400 + shipping?
Old Dec 1, 2005 | 06:22 PM
Z284thgen's Avatar
Re: Guaging interest: Eagle 4340 357 kit
holy heck make your damn mind up
and like i said in the other thread....... on my first post
Old Dec 1, 2005 | 06:59 PM
jsetzer's Avatar
So hard to do..... I have a ton of stuff that needs to be done, I may have to settle on a cheaper bottom end to afford the new topend, clutch, etc etc
Old Dec 1, 2005 | 07:12 PM
Z284thgen's Avatar
just dont let my lil list of new/used vendors leak out
Old Dec 1, 2005 | 08:07 PM
jsetzer's Avatar
Secret is safe with me
Old Dec 2, 2005 | 10:25 AM
jsetzer's Avatar
Obo?
Old Dec 2, 2005 | 10:55 AM
pineapplesink6's Avatar
whats your lowest price? just curious.
Old Dec 2, 2005 | 11:11 AM
jsetzer's Avatar
Didn't want to go much lower than that. I would lose more money than I can deal with.
I want to sell this without too much loss so I can do a weak crappy stockish rebuild and save money in the long run.
Throw me an offer.
Old Dec 3, 2005 | 10:06 AM
jsetzer's Avatar
If no one wants I will use it.
Old Dec 3, 2005 | 10:42 AM
jerminator96's Avatar
Is it balanced?
Old Dec 3, 2005 | 11:45 AM
marshall93z's Avatar
Sure it isn't .040 over??!!
Old Dec 3, 2005 | 02:10 PM
Z284thgen's Avatar
with the 3.5 stroke crank it becomes a 357ci
Old Dec 3, 2005 | 03:21 PM
jsetzer's Avatar
Not balanced, let your machine shop do that. I have seen horror stories with them being balanced and then shipped. I have already built one of these kits and the shop took material off the crank, none was needed added.
.030 over with 3.5 stroke. Stock stroke is 3.48.
Old Dec 3, 2005 | 09:04 PM
Yeah thats all i was really afraid of. The machine shop i have picked out is great but he charges a ridiculous amount for balancing if you have to add mallory. Could you tell me about the pistons and where are you located?
Old Dec 4, 2005 | 12:14 PM
jsetzer's Avatar
I am in OKlahoma.
Pistons are flat top with -5cc valve reliefs. With stock heads and stock head gaskets this should be a tad over 11 static compression. With my heads shaved .020 and a .029 gasket I will be @ 11.9.
Heres what I found just googling the pistons
# Ideal for oval track to street/strip applications.
# Forged from 4032 low expansion high silicon aluminum alloy heat treated to SRP specifications
# Forced Pin Oiler for increased wrist pin lubrication
# Pin fitting, and double spiro locks included
# 927-2750-150 wall wrist pin (130 grams) included
# CNC Machined ring grooves accept 1/16 1/16 3/16 rings
SRP Piston Feature:
Cubic Inch Bore Size Stroke Rod Length Comp H/t 58cc 64cc 70cc Dome Volume Gram Weight
355 4.030 3.480 5.7 1.56 11.1 10.3 9.6 -5cc 493
We have the same setup in one car planning on spraying a 300 shot.
LeftoverChinese
Jan 14, 2024 03:03 PM
dylan1303
Aug 12, 2015 02:00 AM
Jun 12, 2015 12:58 PM
Catmaigne
Dec 25, 2014 12:16 PM
formula383
Sep 7, 2002 12:17 AM
