FS: Wilwood Rear Disc Brakes for Ford 9"
Old Nov 28, 2005 | 08:55 PM
RamAir95TA's Avatar
Hello all...
I'm selling a brand new rear disc brake kit for Ford 9" rear ends with the Big-Ford new-style housing ends, the most common ends for aftermarket 9"s for f-bodies. This is Wilwood kit 140-2118. I decided to go with a different brake setup for the rear, so I am selling these. The brackets and rotors were assembled and bolted to the rear axle, but have not seen street use whatsoever. Rotors have a VERY minor dusting of surface rust that will come right off when the brakes are first applied. Here's a link to Wilwood's webpage explaining what you get:
http://www.wilwood.com/BrakeKits/Pages/11/index.asp
Included:
ForgedBillet Dynalite 4 Piston Calipers with aluminum brackets.
HD Aluminum Rotor Mounting Hats with 3 bolt-patterns, including 5x4.75".
HP Series 12.19" Iron Rotors, blank pattern.
PolyMatrix Brake Pads.
Paid over $540 for this brake setup a few months ago, and it is UNUSED. Need to get rid of it ASAP...I'll also include 3 bottles of Wilwood brake fluid.
Asking $450.00 OBO! I won't turn down any reasonable offer.
Thanks for looking!
Old Nov 29, 2005 | 09:51 PM
speedracer69's Avatar
Re: FS: Wilwood Rear Disc Brakes for Ford 9"
Is it just like the pic shown?
Old Nov 30, 2005 | 03:08 PM
RamAir95TA's Avatar
Everything is identical to the picture, minus the rotors. They are not drilled/slotted. I figured that having slotted rear rotors would be a bit much, and not worth the extra dough. The same Dynalite 4-piston calipers in the picture are the same though.
Thanks for the reply!
Old Dec 2, 2005 | 01:59 PM
RamAir95TA's Avatar
To the top.
Old Dec 24, 2005 | 06:22 PM
RamAir95TA's Avatar
To the top. Happy holidays!
Victor Lamb
Aug 26, 2017 02:52 PM
dale3in98
Feb 14, 2015 12:18 PM
Cam's maro
Jan 8, 2015 05:01 AM
NewsBot
Dec 3, 2014 12:30 PM
bossco
Nov 29, 2014 10:18 AM
