Exhaust slip joint seperation
Ok, what s the magic to getting a U-bolt slip joint seperated?
I need to get the Cat section seperated from the rest of the exhaust out back and cannot get the two pipes to come apart for the life of me.
Re: Exhaust slip joint seperation
try a cut-off wheel and slice just the outside pipe , just up to the crease
by heat i meant heating the pipe until the entire crease is orange/red, then wiggle the pipe till it slips out, it can then be reused
THANKS DAVE!!!
A nice quick slice with a cutoff wheel and a portapower wedged between two u-bolts and its all apart with minimal damage and minimal effort... and just a touch over 1 hour between first post and exhaust apart.
I knew I liked this place!!!
F'n1996Z28SS
Aug 23, 2023 11:19 PM
Victor Lamb
Aug 26, 2017 02:52 PM
