Will this fit my LT1
When I put my cam in I want to change the timing chain also. I have a brand new one that I have never used but I am not sure if it will work in an LT1. I don't know that manufacturer but it is stamped "made in USA" on it. Click here
Re: Will this fit my LT1
here is your answer
http://store.summitracing.com/defaul...=egnsearch.asp
click "application" on the part screen
shoebox is 100 percent right! Also, if you convert to 95 up opti you'll need a longer dowell pin on the cam plus a new front cover for that 95 opti and vent lines added to the mix.....Why....I did this conversion to my 94 7 years ago, along with my stroker kit....This is also assuming that the vented opti will actually fit into the stock cam hole...I replaced my cam for 95 up so, I never checked the stock one...
Oops, almost forgot you'll also need a new plug that goes in to the 95 up opti...the 94 looks the same but is to short to contact the pins....Otherwords this will be the most costly replacement for a timing chain on a stock engine....You could just replace it with a stock "from factory, LT1 94 chevy timing gears" or not at all.....
jimbob
jimbob
Originally Posted by L31stang
I hate it when this happens. One person says it will work and one says that it won't! I guess the only way to find out for sure is try it
I was just reading summits years it fits... says it will fit a 94... but they always skip the "install" details.
Originally Posted by jimbob65
shoebox ....This is also assuming that the vented opti will actually fit into the stock cam hole...
jimbob
jimbob
TheGreenZ28
Exhaust System
Dec 6, 2014 10:23 PM
