Will this fit my LT1
Old Sep 14, 2005 | 10:48 PM
L31stang's Avatar
When I put my cam in I want to change the timing chain also. I have a brand new one that I have never used but I am not sure if it will work in an LT1. I don't know that manufacturer but it is stamped "made in USA" on it. Click here
Old Sep 14, 2005 | 10:50 PM
PGM95Z's Avatar
Re: Will this fit my LT1
here is your answer
http://store.summitracing.com/defaul...=egnsearch.asp
click "application" on the part screen
Old Sep 14, 2005 | 10:52 PM
L31stang's Avatar
I know the Lt1 is a roller cam but I thought it was a gen II motor? Is says fits non LS style motors, so is that a "yes it will fit"
Old Sep 14, 2005 | 10:53 PM
Heatmaker's Avatar
Advanced Member
Yes.
Old Sep 14, 2005 | 11:19 PM
So, do you intend to run an electric water pump and convert to a vented opti? You will if you use that timing set (assuming this is for your 1994).
Old Sep 15, 2005 | 07:19 AM
L31stang's Avatar
I hate it when this happens. One person says it will work and one says that it won't! I guess the only way to find out for sure is try it
Old Sep 15, 2005 | 07:49 AM
jimbob65's Avatar
shoebox is 100 percent right! Also, if you convert to 95 up opti you'll need a longer dowell pin on the cam plus a new front cover for that 95 opti and vent lines added to the mix.....Why....I did this conversion to my 94 7 years ago, along with my stroker kit....This is also assuming that the vented opti will actually fit into the stock cam hole...I replaced my cam for 95 up so, I never checked the stock one...
Oops, almost forgot you'll also need a new plug that goes in to the 95 up opti...the 94 looks the same but is to short to contact the pins....Otherwords this will be the most costly replacement for a timing chain on a stock engine....You could just replace it with a stock "from factory, LT1 94 chevy timing gears" or not at all.....
jimbob
Old Sep 15, 2005 | 10:03 AM
Heatmaker's Avatar
Advanced Member
I was just reading summits years it fits... says it will fit a 94... but they always skip the "install" details.
Old Sep 15, 2005 | 09:00 PM
Admiral94's Avatar
Originally Posted by jimbob65
shoebox ....This is also assuming that the vented opti will actually fit into the stock cam hole...
jimbob
As you can see by this picture it doesn't look like the cam will work either with the newer opti.
HectorM52
Jun 23, 2016 08:42 PM
4586
Parts Wanted
Mar 17, 2015 11:24 PM
TheGreenZ28
Exhaust System
Dec 6, 2014 10:23 PM
TYLER94Z28
Dec 3, 2014 07:05 AM
