custom grind cam
Old Aug 16, 2005 | 09:31 AM
white93lt1's Avatar
custom grind cam
how would the grind of the ASA cam preforme in my car?.. My Cousin had a ASA cam in his ls1 and he made very good power and was wondering if i take the specs from it and get a custom one for my 93 how it would do..?? any thoughts...or other suggestions on other cams that will give me decant power all around..
Old Aug 16, 2005 | 09:40 AM
BUBBA's Avatar
Re: custom grind cam
What is an ASA cam?
Old Aug 16, 2005 | 10:17 AM
SStrokerAce's Avatar
The "ASA" cam is a 239/251 .570/.570 106.5 LSA
It's a bit big.
Bret
Old Aug 16, 2005 | 06:43 PM
white93lt1's Avatar
so u think dont go with the ASA grind...what do u suggest
Old Aug 16, 2005 | 07:17 PM
I don't suggest anything on here.... don't want to get the post ****'s after me.
Bret
Old Aug 16, 2005 | 08:59 PM
Hybrid86Z's Avatar
a good cam is only as good as the heads will allow.
on a stock headed car, you can only pull in and release so much air....in which means the "big" cams will not do you any good.
if you want to make good power, look into something along the lines of the comp306, which will net you around 350-360 to the wheels on a stock headed car, depending on if you are a manual, auto, and have aftermarket gears and full boltons.
Old Aug 16, 2005 | 10:54 PM
white93lt1's Avatar
im auto, have minor bolt ons. 3.23 gears, and a 100 shot
Old Aug 16, 2005 | 11:03 PM
Jameslt1TA's Avatar
so a 306 would be a good cam for you. The 306 loves n2o.
Old Aug 16, 2005 | 11:19 PM
Why does everyone think a cam with a wide LSA and lots of exhaust duration always like N2O... if the cam gets less air into the cylinders then it gets less N2O in as well... IMHO a CC306 is not the best thing to get for stock heads, but what do I know.
Bret
Old Aug 16, 2005 | 11:30 PM
Victory Racing's Avatar
Bret
Agreed.
Old Aug 16, 2005 | 11:32 PM
...but what do I know.
Bret
I don't know...what do you know? I do know that if I were to know what you know, I would then know a lot more than I know now...you know?
Old Aug 17, 2005 | 12:06 AM
truedualws6's Avatar
Bret
Come on Bret, I would love to know what the ideal cam/head combo is for
a CA smog legal car with the following:
M6 w/3.73s
stock bottom end
6,000 rpm shift points
no N2O
mid length headers w/full exhaust (cats and muffler)
daily driver w/rush hour traffic
as wide and flat a torque curve as possible
plus all the other crap on my mods list except for the cam and heads. LOL
Old Aug 17, 2005 | 12:12 AM
Truedual....
Ideal would be no emissions. You can't get IDEAL in terms of power with those constraints.
You probably wouldn't like the peak numbers on a setup like that but you could have a doable TQ curve with something like that..... It would just take a lot of other good parts in concert with the cam to work properly.
Shoebox,
I wish I knew everything that I don't know so I would know everything that I don't.
Either way, as I said in Advanced Tech, I don't like being under my own car so I am thankfull for what you know so that I can make my time under my car much lower.
Bret
Old Aug 17, 2005 | 09:42 AM
BUBBA's Avatar
Now if the ASA is off-the-shelf, it's not a "custom" cam is it? Let's be clear about this: a custom cam is a cam that is custom made for a custom mer, specifically ground to the specifications determined by the grinder or the custom mer for a particular application.
Old Aug 17, 2005 | 10:23 AM
Kurt Crosbie's Avatar
Is this ASA cam the cam they used in the American Speed Association?
