6 Speed
Old Apr 29, 2005 | 08:09 PM
Chris_Camaro's Avatar
6 Speed
anyone know of a six speed i could put on my v6, somone mentioned the t-56, thats not possible is it? either way i want to put a 6 speed in it, any sugestions on where i can get one?
Old Apr 29, 2005 | 09:19 PM
Need4Camaro's Avatar
Re: 6 Speed
I believe unless you're throwing out some SERIOUS power, a 6 speed... if there IS one compatible with our cars... Will just be a huge waste of money. Even stock LT1's have trouble in 6th gear (No real accelleration, almost topped off) as if 5th was the end of the shift... Money spent better elsewere but thats just my oppinion...
Old Apr 29, 2005 | 10:18 PM
94m5's Avatar
Re: 6 Speed
Your correct. the V-6 would have a HELL of a time trying to lug in 6th. well, that is, unless you threw a set of say.........5.56's in the rearend. Plus you would need to find a bell housing to mate the t56 up to the engine.
Old Apr 30, 2005 | 02:08 AM
Wolfie's Avatar
Re: 6 Speed
if any of the rwd northstars come with 6 speeds you could use that bellhousing,otherwize you'd have to fab one
Old Apr 30, 2005 | 02:09 AM
Loochy88's Avatar
Re: 6 Speed
for all that money you would be putting in to the tranny, you could do some really nice things to your car. you allready have a m5, 1 more useless gear is not worth the cash. do something useful.
Old Apr 30, 2005 | 02:11 AM
camaroz28racer2's Avatar
Re: 6 Speed
You just need the aftermarket kit for a thirdgen, it has a plate that bolts to the T5 bellhousing.
Old Apr 30, 2005 | 04:15 PM
94m5's Avatar
Re: 6 Speed
you could do that too.....But your not gonna be able to use 6th for anything. The 6 cylinder does'nt produce the torque needed to turn a .50:1 gear ratio
Old Apr 30, 2005 | 07:42 PM
Sergio's Avatar
Re: 6 Speed
Not too mention that the other first 5 gears aren't ideal for the V6 powerband either ....
Like they all say, waste of cash .. Simple as that.
Old May 1, 2005 | 10:25 AM
Re: 6 Speed
i was thinkin about going for handeling, and posibly change my gearing for the canyons. its all still up in the air cus i could do alot more to my car with that money for the tranny, so who knows...still thinkin
Old May 1, 2005 | 10:47 PM
Re: 6 Speed
It would still be too much for the V6. and if you got all 6 gears low enough to run properly then you would actually have better and LONGER accelleration in a 5 speed. You just threw an extra gear in and divided your power band into 6 short divisions when you could have 5 longer divisions which = more speed.
Old May 2, 2005 | 02:21 PM
Fast Caddie's Avatar
Re: 6 Speed
If you put the M6 in it, then go with 4.56 rear gears. 6th gear in the T56 with 4.56s has the about same torque multiplication the A4 does with 3.42s.
T56 6th gear
0.50*4.56= 2.28
4L60 4th gear
0.70*3.42= 2.39
In other words, at 60mph you're turning 1900rpm with both trannies in high gear, ~2400 at 80mph.
I *think* that the V6's A4 exhanges with the V8's, so you should be able to swap the T56 in. The good thing about T56s is that you have narrow ~2000rpm shift extensions, so you'll stay right in the meat of the powerband (i.e. if you shift at 5700, you'll only drop back to 4000 after the shift for gears 1-3, while the 3-4 and 4-5 shifts drop back to 4400rpm). With the 98+ V6s i'm not sure which T56 you should use though (LT1 or LS1, they use different BHs and input shaft length). Might be worth looking into if you have some spare cash to play with.
Old May 7, 2005 | 07:00 PM
Re: 6 Speed
thanks alot for all your advice
Old May 7, 2005 | 07:42 PM
EKO's Avatar
EKO
Re: 6 Speed
I've read elsewhere that V6 and V8 trannies do not match, autos or manuals.
Old May 8, 2005 | 11:51 AM
Re: 6 Speed
ill try to research it and talk to a few machanics, because that would be nice to know, i dont want all top end anyways, i wanted lower gearing for the canyon, i dont need to do 150 , i want my top speed like 120 with 6 gears
AWYEE
Parts Wanted
May 12, 2015 06:58 PM
4586
Apr 27, 2015 06:08 AM
njspder
Middle Atlantic
Mar 5, 2015 05:39 AM
sdn1997rs
Dec 30, 2014 08:30 AM
