ecu problems
Old Feb 17, 2005 | 10:15 PM
jentrys_gurl's Avatar
Exclamation ecu problems
i dont know what is wrong i was told that i have an electrical problem. i have a 2000 v6 camaro. i had it on cruis it slowed down now wont go past 20 mph there is also a gas smell, like raw gas.
Old Feb 18, 2005 | 12:27 PM
Tru2Chevy's Avatar
Re: ecu problems
How does the motor run when you floor the gas from a stop? Does it pull normally until you hit 20 mph? Does it break up at all? Any weird sounds or vibrations?
- Justin
Old Feb 20, 2005 | 01:50 PM
Angry Re: ecu problems
it dosent do any thing now , it wont start, but when i floor it from a dead stop it would accerlerate right from the RPMS but wouldnt from the MPH if that makes any sence, there were vibrations when i would come to a stop and let off the break as if to be coasting or not useing the gas it would jerk real hard untill the gas or brake was used, now when i go out to even try to start it , the car will start but just die again
RUENUF
May 25, 2016 08:10 PM
Klypto
Mar 23, 2016 09:05 AM
RUENUF
Mar 13, 2016 03:39 PM
IgorT.455/406
Mar 12, 2015 03:39 AM
Jonnybegood
Parts Wanted
Feb 10, 2015 07:50 AM
