Smoldered Yet Another Wire!
Old Feb 12, 2005 | 05:13 PM
Need4Camaro's Avatar
Well this is getting old...
Where can I get some heat sheathing / boot protectors... The cheaper the better because I'm on a tight budget, not to mention I need new wires now... Whats a good 8mm wire choice that I can get for $45 or less?
Old Feb 12, 2005 | 05:22 PM
WickEdSix98's Avatar
Re: Smoldered Yet Another Wire!
How do you keep burning them? Do you have them in stock location?
Old Feb 12, 2005 | 05:40 PM
Stock location?
There is no stock location, or atleast not from what I see...
When I got it there were no fastners of any type and wires ran all over the place... I routed them under the manifolds because I can't clear the manifolds if I route them over them...
Old Feb 12, 2005 | 09:40 PM
Ok. The drivers side wires go up from behind the the manifold, and on the passenger side, they go over the top of the intake and down under the manifold. might try to make them fit like that. I am still running stock wires with no problems.
Old Feb 12, 2005 | 10:23 PM
I'll try but I'm ordering 1,200 Degrees Heat Sleaves, Taylor 8MM Spiro's, and Routers...
I shaln't burn another wire again unless I do something stupid...
Old Feb 13, 2005 | 03:23 PM
JJayzX's Avatar
I routed my wire for #6 to thru the back instead of under the manifold also don't your boots have the metal protective boot covers. Mine still does. I just replaced wires cause the stock ones were still there so I thought they needed to be changed due to them being 80,000 miles old but still pretty good condition.
Old Feb 13, 2005 | 03:49 PM
Nope, no boot protectors... Those didn't come till 98 think...
Yo check out my wishlist at http://www.thunderracing.com
Chevy 97 Camaro RS 3.8L Engine
Michael Woods
camaro943400@yahoo.com
One of those will let you see it I believe.
Will these keep me from burning more wires?
Old Feb 13, 2005 | 04:10 PM
JJayzX's Avatar
I think I found your wishlist wasn't easy but I think its this one. Should be good.
1 04-74243 Taylor Spiro-Pro 8mm Spark Plug Wires, 1995-1999 3.8l V6 F-Body, Red $39.99 $39.99
1 04-2562 Taylor Fire Sleeves, Heat Treated Fiberglass, Provides protection up to 1200°F, Pkg of 8, Red $51.99 $51.99
1 04-42820 Taylor 7mm/8mm Clip Style Plug Wire Separators, Red $6.99 $6.99
Total: $98.97
Old Feb 13, 2005 | 04:48 PM
Total: $98.97
Yeah thats deffinately it... How much better are Taylor 8mm's than Bosch 8mm's?
Old Feb 13, 2005 | 10:57 PM
JJayzX's Avatar
I always hear to go with taylor or msd. I have stock ignition stuff right now but when I comeback in a few months I'm going to get the whole msd setup. msd dis-4, msd interface to coils, msd coils, msd wires, and ngk iridium plugs. That will give me smoother idle and acceleration and better gas and lil bit more power of course but nothing huge of course unless prior system sucked and misfiring or whatever.
surreybrad
Apr 22, 2015 06:40 AM
EdgarArmada
Apr 18, 2015 05:20 PM
Brandon Wittmer
Dec 3, 2014 09:28 PM
Ryabut98
Sep 3, 2002 11:45 PM
kandied91z
Aug 6, 2002 01:18 AM
