Fuse keeps busting, what's wrong?
My turn signal buss fuse is busting a lot. It first happend early this summer, i replaced it, no big deal. Happend again at the end of the summer, fixed it, no big deal. Happend last week, replaced it with a 30 buss fuse instead of the 20. Then it busted a day later, replaced it, 30 again. Broke coupld hours later. Now it's busting when the car is turned on.
As for as things electircal done to the car: White faced indiglo gauges, checked the connection, and it seems to be fine. I have an aftermarket headunit, and cd changer. I havn't taken out the headunit to check the connections.
I recently changed the shifter in my car, and the car used to be an auto, so there is some electical connections in the console from the t56 swap, havn't checked those yet. Maybe one of them got bumped when i installed the shifter.
All you electircal experts, where would be the most likely place for this problem to originate from?
Re: Fuse keeps busting, what's wrong?
i had the same thing happen, my turn single wireing harness was grounding out on the stearing colume. i just bought the whole harness, droped the streaing colume down and replaced it.
Formula Steve
Sep 19, 2023 08:31 AM
autoxr166
Sep 25, 2015 04:21 PM
