Fuse keeps busting, what's wrong?
Old Sep 16, 2004 | 09:39 AM
rlax31's Avatar
My turn signal buss fuse is busting a lot. It first happend early this summer, i replaced it, no big deal. Happend again at the end of the summer, fixed it, no big deal. Happend last week, replaced it with a 30 buss fuse instead of the 20. Then it busted a day later, replaced it, 30 again. Broke coupld hours later. Now it's busting when the car is turned on.
As for as things electircal done to the car: White faced indiglo gauges, checked the connection, and it seems to be fine. I have an aftermarket headunit, and cd changer. I havn't taken out the headunit to check the connections.
I recently changed the shifter in my car, and the car used to be an auto, so there is some electical connections in the console from the t56 swap, havn't checked those yet. Maybe one of them got bumped when i installed the shifter.
All you electircal experts, where would be the most likely place for this problem to originate from?
Old Sep 16, 2004 | 10:13 AM
superman96ta's Avatar
Re: Fuse keeps busting, what's wrong?
i had the same thing happen, my turn single wireing harness was grounding out on the stearing colume. i just bought the whole harness, droped the streaing colume down and replaced it.
Old Sep 16, 2004 | 10:15 AM
rlax31's Avatar
damn, don't want to have to do that. where on the colomn is the harness? is the harness colored?
Formula Steve
Sep 19, 2023 08:31 AM
IndyZman
Oct 22, 2015 02:17 PM
9t4lt4z28
Oct 2, 2015 10:28 AM
fift5
11
Oct 1, 2015 10:31 AM
autoxr166
Sep 25, 2015 04:21 PM
