AIR compents
AIR compents
http://shbox.com/1/air_pump_recall.jpg
The bleed valve harness....I have this on my car, but the description says that the bleed valve harness was only for the 96-97 models....well on my 94 I have that harness? I'm confuesed, I am removing my EGR/AIR and should I just remove this too?
Did you have the recall done to your car? I didn't on my 1995 and I don't have a bleed valve. The valve may have been added with the recall stuff. Obviously, if you remove the AIR pump, you don't need the valve, either.
Latronaxe
May 14, 2015 01:23 PM
squarehead
Jan 15, 2015 07:02 PM
95chwagon
Jan 13, 2015 09:19 PM
