main bearing cap bolts threads
Old Mar 13, 2004 | 07:11 AM
pearlpurple's Avatar
when putting your main bearing caps back together for final assembly, what if anything do you coat the bolt threads with??
Old Mar 13, 2004 | 07:28 AM
rskrause's Avatar
Moderator
Re: main bearing cap bolts threads
You need to use a thread lubricant that corresponds to the torque specs you are using. Since I use ARP fasteners, I use the lube that they supply, called "ARP Moly" lube. The chart here http://www.arp-bolts.com/pages/tech/images/fasttorq.pdf gives some general guidance wrt torque specs using ARP Moly lube. Notice how the specs for oil are higher, that's 'cause it's more slippery than the moly lube and therefore requires more torque to achieve the same clamping force.
Rich Krause
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
maybe2fast
Mar 16, 2015 09:45 AM
DirtyDaveW
Mar 15, 2015 07:01 PM
