a little sand left in my intake from sand blasting.. HELP
ok, when my intake was powdercoated, the guy didn't get all the sand out of it. I already preasure washed it and that didn't help... it just ended up scratching the top of the intake up. (those little buggers take off with preasure washing) anyways... I can still see some sand in there... I spent most of the night using my air compressor to try to blow the sand out... now I'm itching like crazy, but I still know there is more sand in there.... what do you suggest?
Originally posted by 1darkz
wash several times with soap and water after you pull all the plugs out if you havent done so already. anything left after that should be minimal if any
Originally posted by smokin5s
plugs don't go into the intake.. so why would I pull them? the intake is not on the car right now BTW.... but the sand is inside of the intake.
I don't think you want to take a chance that any sand is anywhere in your intake.
Originally posted by shoebox
He is referring to the passage plugs that are under the metal shield on the bottom of the intake.
carguyshu
Jan 22, 2017 11:19 AM
CGM2010CAMARO
Apr 7, 2015 07:44 PM
1996LT1Z28
Middle Atlantic
Dec 4, 2014 09:37 PM
1996LT1Z28
Dec 4, 2014 09:20 PM
